Hey guys another serp belt question, Im trying to loosen the tension pully nut and need to know if it is just super super tight or is it a left hand thread?
You should let us know what year you are working with when you ask questions, it helps us answer you better. I assume from your user name you have a '98? Did you loosen the idler pulley first, by loosening the bolt it rotates on?
