Old August 3rd, 2009, 03:32
newjeepowner newjeepowner is offline
Replaced the crank sensor. Still won't start.
Saturday I was driving home and the check engine light came on. Got home and parked it. 3 hours later got in it and would not start. Borrowed a scan tool and got a Crank sensor error. I disconnected the battery and then climbed underneath to install a new sensor. Reconnected the battery which cleared the engine light. Tried starting it. Would not fire up. Does not seem to be getting spark from the coil. No check engine lights have come up. What should I do/replace next? This is on a 1999 with a 4.0
Old August 3rd, 2009, 08:48
birchlakeXJ's Avatar
birchlakeXJ birchlakeXJ is offline
Re: Replaced the crank sensor. Still won't start.
Ensure that the "connector" for the crank sensor is clean. A can of spray electrical contact cleaner is good for that purpose. Also, there is a crank sensor connector inside the engine bay near the firewall/#6 injector. Unplug that and clean that too. If it is dirty, it can inhibit the crank sensor signal from making it to the computer.
Old August 3rd, 2009, 08:56
wim hoppenbrouwers's Avatar
wim hoppenbrouwers wim hoppenbrouwers is offline
Hallo. Maybe a shot in the dark: the ASD relay? If there is no spark.
Old August 4th, 2009, 09:34
CharlesS's Avatar
CharlesS CharlesS is offline
http://www.naxja.org/forum/showthrea...1003757&page=2
Might want to read this Forum thread.... There are two CPS's.... Crank Position Sensor and Camshaft Position Sensor....
Use the posted troubleshooting information to confirm that your CPS is working properly....
Old August 4th, 2009, 10:41
hobbsar hobbsar is offline
Cam position sensor will do this. If it goes out while the engine is running, the ECU uses a pre mapped curve to run the engine. This will work until the engine is shut off, then it will not re-start.
Old August 5th, 2009, 19:42
It was the cam sensor/pickup coil. The little magnet fell off the unit. Thanks everyone.
p0138, replaced o2 sensor and lights still on rockhard4x4 OEM Tech Discussion 2 June 21st, 2009 08:03
P171 after O2 sensor replaced SparkChaser OEM Tech Discussion 3 July 6th, 2008 23:48
Oxygen Sensor----- Should it be replaced? cherokee4fun OEM Tech Discussion 2 October 7th, 2007 10:16
Replaced Oil Pressure sensor. Is this a normal read? Plays For Jeeps OEM Tech Discussion 10 April 13th, 2007 13:56
crank-crank-crank-crank-cra... [wait...] crank-crank-START! iBran OEM Tech Discussion 20 October 21st, 2005 17:33
