LJRockstar
- Hunterdon County, NJ
Has anyone ever swapped out parts with a pre-airbag XJ? I'm sure it's been done, but is there a way to do it that doesn't set codes or trigger a malfunction light? I never really liked the idea of a Bomb pointed at my face, and I'm 6'3" with a non tilt column. If I'm gonna have to swap for a tilt, I want to get one of the older (much better looking) steering wheels too.
I live in the nanny state of NY so it won't pass inspection if there's a code set. There has to be some configuration of resistors and/or diodes that will trick the ecu into thinking everything is normal.
Ideally I want the same wheel that was in my '90. All black with the trapezoid shaped center horn button, but I'd settle for any of them really. I just hate looking at the one that's in here now. It just doesn't look right.
Anyone have some input on this?
