NP231 Front Yoke Removal
tgregg
NAXJA Member #1444
I'm trying to remove the front yoke in the process of replacing the chain. My impact is not removing the nut. QUESTION is the nut right hand or left hand thread. I'm assuming it is a normal thread not reverse. Am I correct??
My XJ was driven for a long time without the front driveshaft installed which I think let "stuff" impact the open yoke and the nut. I am soaking it with WD40 hoping it will loosen.
Hold the yoke with a large pipe wrench(3' long) if you have one, and break the nut loose with a 1/2" breaker-bar and maybe some pipe over the handle of that.
Yea! I need a bigger pipe wrench. Mine is too small. Actually I had the pipe wrench up against the frame and pulling on the breaker bar I was moving the whole car on the jack stands. I guess I'll try again in the AM after it soaks a while.
WD-40 is NOt a penetrant,get some PB blaster!
WobblesXJ said:
put some D into it, girly man.
Hey, I'm OLD. At 62 I still race a YZ 450 in D37 desert races but I for sure am not as strong as I used to be. I think the new impact gun and PB blaster are good ideas!
