tow/recovery points to hook your strap to
clayman
San Diego
i was reading the post about metal hooks and i read this ...
"Please also make sure your XJ has the proper tow/recovery points to hook your strap to before you take it out and get stuck."
and it reminded me i had a question to ask.
how and where should proper tow/recovery points be added to my jeep?
i have a 2wd and have been stuck a few times in deep sand; and only because i didnt have much of any other choice i was towed out by my bumper. ive been meaning to ask where a good place to be towed out is for a while.
cassio said:
if its a 2wd drive
you can just put the strap on to your front axle
Bad idea.
PROPER tow points would be tow hooks (with appropriate brackets) in the front, and either a tow hook (again, with brackets) in the back or (preferably) a Class 3 receiver hitch.
Eagle said:
Bad idea.
in the front meaning on the bumper? know any companies that make good hooks and brackets? thanks for the help.
Rusty's at www.rustysoffroad.com makes brackets - I don't have personal experience with them.
I opted for a front receiver from Draw-Tite. Brackets and hooks run about $75, the receiver was about $100. I like the extra flexability of a front hitch (winch mount - someday, pushing a camper into tight places). On my 2000 the reciever sits high and tight beneath the front bumper and clearance has never been a problem - yet.
Just some more options to consider.
my suggestion as well... i think it spreads the load out more equally on the unibody... hiddenhitch makes a front reciever too but take the drawtite hitch if at all possible...
Hooks also have a tendency (not always, but it is known to happen) to bend or break, usually if a lateral pull is involved. Failures with receivers are less common, but can still happen. As mentioned, though, receivers do have the added flexibility of allowing you to plug a number of useful things into them.
