Old September 13th, 2017, 23:42
Sub Zero Sub Zero is offline
Cruise control available on manual transmission models?
Does anybody know if the manual transmission xj was available with cruise control? I'm thinking about adding factory cruise to my manual 94. I know with the automatics it's basically plug and play, it looks like the manual should be the same with the exception of the clutch switch. There is no switch on my clutch pedal to cancel the cruise when the clutch is depressed. I couldn't see a harness to connect a clutch switch but I may have missed it. Does anybody have any info that could help me out?
Old September 14th, 2017, 08:02
Anak's Avatar
Anak Anak is offline
Mostly Harmless
Re: Cruise control available on manual transmission models?
Yes, cruise control was available with a manual. My '96 with an AX15 has it.
I do not have any details regarding a clutch switch. I have never gone hunting for that.
Old September 14th, 2017, 12:30
asymptonic asymptonic is offline
Ditto on my 98. It does cut off when you clutch in, but I never do that since you'll get a little rev before the switch gets it. I tap the brake or use the cancel button.
Old September 14th, 2017, 17:04
Does the cruise kick off when you push the clutch? 96 is the older bodystyle like mine and I think the harness should be pretty close
Old September 14th, 2017, 17:17
Or do you have to have the clutch pushed in to start it? If you do then you have a switch
Old September 14th, 2017, 17:34
Yes. Interestingly, I always floor the clutch to start, so I'm not sure if its the same switch. When I clutch in with cruise on, you don't have to depress it fully for CC to disable.
Old September 14th, 2017, 18:11
Cummins90 Cummins90 is offline
My 96 ax-15 does not require the clutch to be depressed to start.
Old September 14th, 2017, 19:42
Interesting. Hopefully I can find all the cruise parts at my local JY and test it out. I'll update with results once I get everything hooked up
Old September 14th, 2017, 20:29
Anak's Avatar
Mostly Harmless
Same here. I put the shifter in neutral and then start without depressing the clutch. In theory that is easier on the thrust bearings.
As mentioned by asymptonic, the engine will rev if an attempt is made to shift while cruise control is engaged. CC will then disengage. For all I know there is not a switch, but rather the computer senses the sudden climb in RPMs and then disconnects the CC.
Old September 14th, 2017, 23:07
I was actually just discussing this idea with a buddy. I've never seen a CC system work like that but hopefully it's ran through the computer like you said. I guess the only way to know for sure is to hook it up and see if it works.
Old September 15th, 2017, 08:32
Oh, interesting theory. Computer would have to check the throttle too, because I've definitely floored it to pass with CC on and it stays on.
Manual to auto swap, manual control, what´s needed luischia Modified Tech Discussion 4 July 29th, 2015 08:03
Cruise control from 97 DrMoab For Sale: Private Party Only. XJ ITEMS ONLY 0 August 15th, 2013 07:19
2000 - 2001 Jeep Cherokee Valve Body Solenoid for Models with 45RFE Transmission 1ATony Vendor's Specials 1 January 18th, 2013 10:50
Cruise on a Manual XJ dingo151 OEM Tech Discussion 22 November 7th, 2012 07:19
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
