Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > OEM Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old January 12th, 2008, 10:23
stxcherokee's Avatar
stxcherokee stxcherokee is offline
help needed
ok, so i put on my snorkle a few weeks ago and everything went smoothly.
i took out the stock airbox and put in the k&n universal cone filter sealed system. i have a 95 4.0 6 and i noticed 2 tubes/hoses coming from the old (stock intake). I hooked up the one that went to the valve cover, but the other looks like it goes to a canister, what or where do i hook this up, or is it not neccessary. 4x4 ac, everything still works fine.
the only problem i've had sense the install is my oil cap was blowing out tons of oil, thick smoke, could this be from that hose not being hooked up or it's time to go? anyways replaced the cap today, just curious what to do with the other hose
Old January 13th, 2008, 07:16
Re: help needed
ok, so nobody else has this line or noone is willing to help? c'mon guys every time i ask a question i get no response. why did i even pay for the site?
Old January 13th, 2008, 07:33
Ray H's Avatar
Ray H Ray H is offline
Re: help needed
I searched to see if you truely havent gotten any responses to recent posts. You have got some help.
Anyway, I cant answer your question because Im not familiar with the snorkle setup. I dont believe in coincidence. If the problem started when you installed the snorkle, then thats where to start.
Judging from your recent posts, you have a habit of disconnecting vacuum lines and failing to connect them back up or you just rig them with duct tape or something. My advice is to get ahold of a vacuum diagram from a Chiltons or FSM and start by going through your vacuum system from top to bottom to make sure you havent disconnected lines and neglected to connect them back.
Old January 13th, 2008, 09:16
Jess Jess is offline
Re: help needed
the other line goes to the charcoal canister. The problem you have now is probably due to a clogged PCV (port on top of valve cover in rear). If your change it, your blowby problem may also be fixed.
HP 30 3.73 or 4.56 needed northgazj Wanted: Private Party Only 0 January 24th, 2007 13:30
Anyone with a stock leaf set? Only one needed and only long leaf needed RWKHausSupply SoCal Chapter 5 September 27th, 2006 21:16
needed trailrunner Colorado Chapter 0 October 10th, 2005 07:01
mj soa help needed(please) aldumoul Modified Tech Discussion 1 November 10th, 2004 17:36
242 needed crazy4mopar Sierra Chapter 13 August 8th, 2004 21:35
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
