Old January 11th, 2018, 03:10
Precious88xj Precious88xj is offline
Coolant sensor/idle problem
1988 Jeep xj 4.0 4x4 aw4
So I recently swapped in a high output motor and forgot to install the coolant sensor that mounts to the motor on the renix. I kept my electrical system from the renix. Would that cause me a rough idle I donít have it connected?
Also I wonít be able to install it to itís original location can I adapt it to the water outlet where the temp sensor goes located for the H.O
Old January 11th, 2018, 18:49
BenWheelin BenWheelin is offline
Re: Coolant sensor/idle problem
The one in the head is for the gauge and nothing else. Check your ignition system, air filter, EGR valve, etc.
I think Renix has a knock sensor in the block, that would make sense.
Old January 12th, 2018, 08:51
techno1154's Avatar
techno1154 techno1154 is offline
Are you referring to the sensor in the back of the engine or the one at the front? They both serve different purposes.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old January 12th, 2018, 12:32
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is offline
The one in the side of the block is important if that is what you’re referring to. If there are no provisions for it on the new motor I don’t see why it wouldn’t work in the thermostat housing like on later models.
Coolant temp sensor renix idle problems? Precious88xj OEM Tech Discussion 8 January 14th, 2018 12:23
Voltage problem with coolant temp sensor. AnthonyZ28 Modified Tech Discussion 4 April 11th, 2012 18:22
Coolant Sensor problem Brandon77 OEM Tech Discussion 3 October 13th, 2011 12:18
Coolant temp sensor Jeff1 OEM Tech Discussion 8 February 27th, 2008 21:51
Coolant Temp Sensor causes High Idle RENIX? Storydude OEM Tech Discussion 3 June 8th, 2005 19:34
