Old December 27th, 2017, 16:21
Crab Pot Crab Pot is offline
1999 Bone Stock XJ Sport
New Guy Here.
Been lurking around here since I decided to buy an XJ about a year ago. As I age my tolerance of the cold and dust in my CJ5 has become limited. And I'm at the point where air conditioning for me and the wife is a nice luxury to have.
Finally pulled the trigger before Christmas and bought me a stock XJ with 146K miles. Not the "Little Ole Lady from Pasadena" score but close.
This rig is going to be my daily driver so I won't be getting all "Rubicon/Fordyce Trail" ready.
Which brings me to my questions that I'd appreciate some guidance on.
My main wheeling will be on hunting and camping trips. Minor to moderate skill level obstacles. I have many years of saddle time in various Jeeps and Scouts so it's not a skill thing, it's a money thing.
What I'd like opinions on are how high of a lift can I go without changing various other hoses, cables, and ect?
What size tire?
Should I upgrade axles?
What bolt on's would you recommend?
Stuff like that.
I'm $4000 into the truck now and think a budget of $5-6K should get me set up real nicely and keep my wife from filing divorce papers. I have boats too so she knows how I get.
Anyway, I'm new here so if I posted this in the wrong section please move it to where it needs to go.
Thanks in advance,
Steve
Old December 27th, 2017, 20:39
trippled trippled is offline
Re: 1999 Bone Stock XJ Sport
If it we're me for mostly doing service road type stuff and maybe a little more, I'd do a 2in budget boost, 30x9.5 tires, t case skid and some sway bar discos. If you can drive that setup can get you a ton of places. Tow points front and rear too. Your rear leaf condition will dictate what direction you go. If they're a little worn but not totally clapped out, I'd go for a full length 2.5 add a leaf. If they're pretty saggy you may need new springs.
Old December 27th, 2017, 21:19
Thanks Trippled.
I'll start researching this.
Old December 28th, 2017, 08:00
x-jay vision x-jay vision is offline
Put some 235/75 all-terrain tires on it, replace the rear leaf springs if they are sagging and put a true-trac in the rear axle.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Old December 28th, 2017, 08:55
Kittrell's Avatar
Kittrell Kittrell is offline
OME lift and shocks, some manner of HD tracbar, 31' tires, 4.10 gears, true Trac limited slip front and rear, rock rails, skid plates, tow hooks.
HD SYE and driveshaft depending on how it reacts to the lift.
Old December 28th, 2017, 09:19
burntkat burntkat is offline
NAXJA Member #1145
Pretty much this, except nix the tow hooks and go with a front receiver hitch.
MUCH stronger, will reinforce the entire front end, and won't bend on side-pulls. Plus, front receiver hitch for spotting trailers, or attaching a removable winch tray to.
Also, I'd go with RE springs and Doetsch Tech shocks, personally.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old December 28th, 2017, 17:04
RCP Phx RCP Phx is offline
All good info so far, but since it's a 99 I would get the lift done to see if you have any drivetrain issues. After that at least some rocker protection and go from there.
What axle do you have?
Old December 28th, 2017, 19:22
Thanks everyone, I have a lot of reading to do.
I bought a brand new set of Smittybilt rock sliders on Craig's List for $175, still in the box.
I plan on putting a Rough Country front winch bumper and a JCR (?) rear with spare tire rack.
Once I get those knocked out up it will go up, I'm thinking 3.5" with 31" tires. Still thinking on the tires but I like semi-narrow tires like tripped suggested.
No idea on wheels yet, guess that's another discussion.
Armor of the oil pan, t-case, and tank should wrap it up.
I'm still open to other thoughts and suggestions so please keep them coming.
Can't figure out photo posting...is there a way to post photos without using a service?
Sorry- Not sure which axles I have. Need to climb under there and figure that out.
Old December 28th, 2017, 22:43
SleeperXJ's Avatar
SleeperXJ SleeperXJ is offline
I'm going to second Kittrell's recommendation, OME springs and shocks.
I'll add Dana 44 rear axle if you can find one at a good price.
I had a TrueTrack in a Dana 35 that didn't last long. If you have a Chrysler 8.25,
that should do much better for you.
Old December 29th, 2017, 07:06
NAXJA Member #1145
If he has a ChryCo 8.25 and isn't building this thing extreme, it will be just fine. By all means if it's the D35, get rid of it in favor of a D44.
Old December 29th, 2017, 07:42
BenWheelin BenWheelin is offline
Buy a set of 17" steel wheels for a Magnum/Charger. Lot easier to find spares on the road. Tons of ten ply all terrains to chose from in 17 inch.
I've yet to build a 97-01 but I find four inches of lift is where you need to start accommodating things.
Old December 29th, 2017, 08:29
smokeyyank's Avatar
smokeyyank smokeyyank is offline
You have to use a host to post photos. Imgur is what a lot have switched to after the photobucket flop.
What Kittrell said is spot on. You should have a 8.25 in the rear and HP30 up front. Both are great axles and more than enough for what you need. If by some chance you have a 35 rear a 8.8 is a great swap and cheaper than a D44. Will also have 31 spline axles, LSD and disc brakes. It is a little bigger of an axle and some will say you'll "dig trenches with 31's" but I liked it on my setup when I had it and never any issues with hanging too low.
Also suggest upgrading your tie rod and steering. Cheap and easy fix is the ZJ tire rod, but whatever you do get a solid tie rod. Nothing like tacoing the wheels and being stranded because you over looked that part.
Definitely go with 10.5 tires. 12.5 on 31's look silly.
Old December 29th, 2017, 09:49
If he has a D35 then he most likely has ABS brakes, so that would need to be addressed also!
Old December 29th, 2017, 10:08
I wouldn't even consider that for 2 reasons!
Unless your running 35's or larger, you don't get enough sidewall height.
15" tire are the most common, specially on the trail!
Old December 29th, 2017, 10:32
NAXJA Member #1145
He is probably suggesting those for brake clearance. I am not familiar with that setup though.
1993 Cherokee Sport - 5 speed manual, bone stock, $800 Menzenski NAC Classifieds 0 July 9th, 2010 12:35
1999 Jeep Cherokee Sport - stock duke000088 NAC Classifieds 4 June 3rd, 2010 09:25
tow front stock cherokee seats 1999 sport aparke4 For Sale: Private Party Only. XJ ITEMS ONLY 5 November 10th, 2006 14:53
Feeler: 2001 Sport 41.5K Bone stock (FS) BMWNUTw/XJ For Sale: Private Party Only. XJ ITEMS ONLY 11 January 7th, 2005 09:22
