Some insight please
I'm kinda confused--you need the output shaft or the yoke, or both?
You can buy the front output yoke for as little as $34. As I hate it when the driveshaft lets go and tears up very expensive components I would probably spend more, around $80, for a higher quality part.
Check with Advance Adapters, they should get you on the right path even if they don't have one in stock.
Thats exactly my worries... i check them out thanks
