I've used Seafoam in my gas twice in the last 2500 miles, but have not used it directly in the intake. What are the benefits of doing that? Can it hurt anything?
My XJ (2000 model, 4.0L, 140,000 miles) idles a little rough and the idle jumps around between ~450 to ~600 RPM. :shiver: It has good power and gets 21-22 MPG on the highway, so I can't complain about performance. I've cleaned the IAC and the throttle body with spray cleaner, but I'm just wondering if Seafoam in the intake is the solution. Also, the engine, at idle, has a knocking sound that seems to come from the valve cover. My local mechanic said that it's piston slap and that it's perfectly normal for that engine and won't do any harm. Does that sound right?
