Red97XJ
- Northern Indiana
I got a sweet CO2 10lb tank from formattfab, I am lovin it. Got it mounted up to the top of my cargo box. The box itself has two huge "L" brackets at rear of box that BOLT thru the floor (no self tappers) and big lag bolts into the box. The front of box is cut on angle to match back of seat (never wheel with seat back down). Then the tank holder is bolted to flat stock that is Lagged to side of box (thru 2x6) and goes to seatbelt bolt/mount. To mount to the seatbelt mount, I just took bolt out, and there is a spacer, I ground it down by the thickness of the steel then rebolt. The CO2 mount itself is also screwed down to top of box with 5 screws to the plywood. confusing, just look at pics.
Here is pics of the CO2 mount.
http://share.shutterfly.com/osi.jsp?i=EeBMmLJy4atXZA
Here are some pics of the Cargo box itself.
http://share.shutterfly.com/osi.jsp?i=EeBMmLJy4atXRg
Hope this can help someone. If so, let me know, I can sure use the green points!
Later,
Jason
Hope to see you on the trial, you can pull me out!
Later,
Jason
