Engine removal
smokeyyank
Looking for some tips to remove the driveline (engine, trans, tcase) from the XJ. Basically I'm going to strip and part the rig out. I've already pulled of the axles and drive shafts. Was planning on pulling the front clip of as well. Does have AC but is not charged. Is everything pretty straight forward or? Thanks
Cool, thanks. Hoping the old man and I can knock it out in a weekend.
2 of you should be able to do it easily in a weekend -- take off the front clip 1st if your going to do it anyway -- will make pulling the motor and trans easier
