Old March 25th, 2015, 07:43
LED Alternator Light with PCM Controlled Alternator???
I hope someone can help he out here..... I am building a custom steel / Aluminum dash with all aftermarket gauges and lights. I thought I had the Alternator light all set in my head, then I came across something I didn't expect. I thought I would hook up the traditional LED light and resistor the field side of the alternator, then I found that these alternators are PCM controlled.
Does anyone know if a typical charge indicator light would work on the alternator? Or, if there is a different way to hook it up?
XJ is what's left of a 2001. Alternator is a relocated 2001 136A WJ 4.0L alternator, but same hook up to XJ PCM. There are so many things in progress (torn apart) on the jeep right now that I cant start it up and test wires right now, so I'm hoping a Jeep wiring guru can chime in.
Since everyone loves pictures, here's one of the in progress dash (1/2" LED indicators are now under each of the gauges)...
Different alternator brackets for different years/alternator upgrades for a 2000? krakhedd Modified Tech Discussion 6 February 15th, 2014 10:53
Alternator dummie light is on. kevswens20 OEM Tech Discussion 5 February 28th, 2012 13:12
I upgraded my alternator to the 136a alternator from a ZJ whats next? Demolition_x Modified Tech Discussion 16 July 22nd, 2011 09:18
GEN/alternator light is on stevieb OEM Tech Discussion 4 September 13th, 2009 14:23
Alternator light won't shut off. pabloconrad Colorado Chapter 3 March 13th, 2006 23:49
