Old December 3rd, 2017, 21:12
lawsoncl lawsoncl is offline
Re: High Transmission Pressure & Crank Walk | Should I Replace Tranny?
Originally Posted by Ecomike View Post
Was his pressure calibrated???? I doubt it was!!!!!
Guessing an analog gauge since the numbers were rounded off to the tens.
Old December 3rd, 2017, 22:06
BALTANAKT BALTANAKT is offline
FWIW, the AW4 tranny is pretty much an indestructible beast.
What tranny fluid was in it and what the fluid temp when he tested it?
How was the test run, with a bad engine crank attached to it?
Good points. No idea on either counts.
The comical thing the engine runs really well, despite the destruction happening inside.
Old December 3rd, 2017, 22:27
Curious, how much endplay does the crank have?
Old December 4th, 2017, 06:26
A good 3/8"1/4".
What causes "crank walk" to occur? BALTANAKT OEM Tech Discussion 13 September 18th, 2017 07:37
To replace crank sensor or not?... bradleyheathhays OEM Tech Discussion 1 September 30th, 2016 00:06
Diagnose AC system? Low pressure good, not so much on High pressure Magus2727 OEM Tech Discussion 14 June 26th, 2011 15:17
ever replace a bell crank? thetinman OEM Tech Discussion 17 August 26th, 2010 09:06
Replace the crank from underneath? stephenspann27 OEM Tech Discussion 17 July 4th, 2009 09:51
