Old February 11th, 2009, 15:40
98_XJ_Classic's Avatar
98_XJ_Classic 98_XJ_Classic is offline
washer solution
Ok guys my rear wiper works great (the actual wiper blade part) but the window washer fluid is not spraying out. any ideas on what it could be?
O I have a 98 classic
Old February 11th, 2009, 18:29
8Mud's Avatar
8Mud 8Mud is offline
Re: washer solution
There are two pumps in the fluid container, I've had them gum up. I've also had the hose in the rear hatch break and fill the hatch with washer fluid.
Old February 11th, 2009, 21:53
10334226's Avatar
10334226 10334226 is offline
Re: washer solution
And sometimes the rear nozzle will clogg up, or crack, and come apart. Try disconnecting your washer lines, and blowing compressed air through them.
Old February 12th, 2009, 06:43
winterbeater's Avatar
winterbeater winterbeater is offline
Re: washer solution
There is a filter above the rear hatch that can clog up.
Old February 12th, 2009, 07:28
CharlesS's Avatar
CharlesS CharlesS is offline
Re: washer solution
As others have posted.... check the sprayer nozzle to see if its plugged with wax or other crud.
IF the nozzle is not the problem.....
Disconnect hose at the rear windshield washer pump to see if water comes out when the rear washer button is pressed, if not... then the problem is either the pump, the wiring or the switch....
Check wiring at the pump for voltage; if none the check the switch for voltage entering and leaving....
97+ W/Cut fenders...washer bottle solution??? sjd78 Modified Tech Discussion 16 March 29th, 2007 22:16
best solution kumes12688 Modified Tech Discussion 5 October 18th, 2006 17:06
SYE/CV SOLUTION?? theNAST1EST Modified Tech Discussion 12 September 7th, 2006 15:55
is this the solution for overheating? herreraxto Modified Tech Discussion 4 July 1st, 2004 12:45
Solution to your D30 Hi Steer needs useless For Sale: Private Party Only. XJ ITEMS ONLY 3 December 9th, 2003 09:01
