- MilkyWay Galaxy
For those of us with 4.0 engine noise, and/or high oil consumption, lifter ticks etc, we have talked here many times about the use of MMO, Marvel Mystery Oil, Gumout and transmission fluid in the engine oil and others, but I have 2 new suggestions.
History: I have a 2001 Saturn that runs great but for over 120,000 miles (now at 270,000) it has been a serious oil eater (no smoke, no Cat converter or O2 sensor issues, no oil leaks, gets 31 MPGs all day long, spark plugs are always clean) but has used about 1 quart of 20W50 oil every 500 miles for 10 years. I recently found a GM TSB that recognizes it as an issue with the Saturns back in their day, and the fix was to pull the spark plugs, put about 1-2 tablespoons on MMO in the top of each cylinder and cover the plug holes for 24 hours. Then put a paper towel partly in the plug hole, and cover the area with a towel and crank the engine a few times. That throws the MMO excess and soaked paper towel out of the combustion chamber/spark plug hole and loosens up the stuck piston rings. Then reinstall the plugs and fire the engine up.
Like magic, per GM it unsticks the piston rings and stops the excess oil consumption. It might even raise engine compression???
Talked to Cruiser54 yesterday and told him about my new idea of doing this for stuck lifters as well. We both agree it is an awesome idea. Just pull the valve cover, then soak the top of the lifters, then later rotate the crankshaft by hand at the harmonic balancer bolt to rotate the cam shaft, and repeat 1-2 times.
Using pure MMO on top of these directly should work far better and faster than dilute MMO in the engine oil by itself.
Since I have many engines in the 200-300,000 mile ranges, one with occasional ticks on cold start up (Use to be way worse before MMO), I am really stocked about doing both of these to all of them.
