krelja
- New Jersey
Well I finally finished my bumper so I figured I'd post up for some opinions on what Ive done. Click on the pics to make them bigger
I started out with a piece of 2x6x3/16 a cut it down
Then I started making the mounts they are about 18 inches long and also 3/16 thick
Then box in the ends to match the body lines starting to look like a bumper
other side starting to fill the gaps
one d-ring mount welded through and sittin in primer
How to mount the spindle without covering my taillight???
final plan
The tire carrier is pretty straight forward its like almost every other one you see out there its tilted back to go with the body and as high as possible to avoid getting hung up on things so here it is
only sits about 4-5 inches off the hatch
so there it is I also picked up offroad only's liteplate it has a liscense plate light and 3rd brake light built in lets hear what you think
final plan
