Boostwerks.com
- Colorado
... Ok it has nothing to do with Cummins, but it sure does pull like one.
With over four years in the making the Boostwerks XJ is finally turbo’d! I’ve been testing the rig for a little over a month now and have only good things to say. I’m running about 8lbs of boost which has been more than enough power to pull on my buddies boxer powered Subaru legacy. Not to mention that I’m on 33 mud terrains and still have the 3.55 factory gears. I’ve been working on this project for a long time and have put more time and thought into it than any project that I’ve done to date. I’ve compiled this thread for your viewing pleasure with over 170 pictures! The pictures detail the entire build process, and include all the parts I’ve used in the setup. I hope that this build thread will disprove some of you doubters as well as inspire some to tackle your own boosted 4.0L project.
Background:
The road has been long and paved with many unforeseeable challenges, but the results have been well worth the effort. As some of you know, I had first tried a manifold based turbo setup for a customer several years ago, but the fitment wasn’t the greatest. Next I developed a remote mount turbo setup that mounted the turbo right behind the transfer case, but like the first setup, this also proved to have fitment issues and the amount of work involved to make it work simply wasn’t worth the cost. After dealing with these problematic first two setups, I decided to revisit the tried and true manifold based setup. With several simple changes to the manifold’s design, I was able to eliminate the fitment issues to comfortably fit a turbo capable of over 500whp, while at the same time keep my AC!
I am a huge stickler for reliability, which is one reason why this setup has taken so long to develop. IMO it’s not worth building something that you won’t feel comfortable driving high up on the mountain or half way across the country. I decided it was worth the extra cost for high quality components and placing them where they would work in harmony with everything else. I hope this build sheds some light that a fairly inexpensive, yet reliable turbo setup is indeed possible for the 4.0L XJ.
Well I think that’s enough introduction and overview. Let’s get on with the build!
Parts list and pictures:
- (Freebie) Boostwerks Manifold
- $650 Borg Warner 57 trim T3/T4 with P trim turbine
- $210 Tial 38mm external WG
- $220 Tial 50mm BOV
- $300 3” Down Pipe and full 3” exhaust with Dynomax ultraflo mufflers
- $40 2” stainless charge piping
- $150 Small Water to air IC
- $100 Bosch IC water pump
- $75 B&M 10x11 Heat exchanger
- $350 AEM FIC 1913 piggy back controller
- $155 AEM ECU patch harness
- $275 40lb Ford Motorsports injectors
- $210 AEM UEGO wideband
- $30 -4AN oil feed line
- $30 -10AN oil drain line
- $40 Various silicon couplers
- $30 Various fittings for oil and water lines
- $70 MSD SS coil
- $30 1 step colder NGK V power plugs
- $50 AEM dryflow filter
- $45 Felpro manifold and oil pan gaskets
- $15 3” flexible silicon intake tube
- $50 Heat wrap for the down pipe and fuel lines
- $50 DEI gold foil
- $50 Boost Gauge and pod
- $20 Misc install goods (copper spray, acetone, antiseize…etc)
Basic parts required: $2120
Extras/hop-ups: $1290
= Rough total: $3,410
*Keep in mind this is the price for all new parts. A good turbo system can be built for considerably less on a budget by sourcing good used parts.*
Background:
- $70 MSD SS coil
- $50 DEI gold foil
