zachtyler
- California
Having trouble finding a compatible speedo cable for my 89 Laredo. It has cruise control, however it doesn't work. I've heard it's a different kind of cable if it has cruise control. The reason I am replacing is the clip that goes to the instrument cluster snapped. It still works but it's just pressed up against it. Anybody know the correct cable I need?
Edit: Further research shows it is a two piece cable, with the second upper piece going to the gauge cluster. So, I might be able to replace just that one I assume?
