Prolly the flasher...change that first....cheaper...
Flasher for TURN SIGS and HAZARDS are usually the same (at least on my 89')If the flashers work pull the flasher and put in where the flasher is for the turn sigs...if they work problem solved....Not too sure if this clear enough but...Flashers are opposite corners from each other...yours may or may not be the same...
