Sway Bar Link rubbing on coil, help!
GreatOdin'sRaven
Las Vegas, NV
I've got a 96 XJ. with rough country 3" lift and 2" spacers.
My sway bar link on left side is rubbing against my coil. How do I fix this? I've searched for hours.
Thanks guys.
Thanks guys.
You need extended links to compensate for that lift. The sway bar has to be set at a specific angle to properly do it's job and have correct geometry.
Swaybar relocation/drop brackets would help with both the length and offset!
Longer sway bar links and relocating the axle side sway bar link mounting points will fix that. As will the already suggested relocation brackets.
