Currie Johnny Joint bushing dimensions
Oatmeal
Cedar City, UT
Hi all,
Anybody have a set of Johnny joint bushings that they could measure for me?
Need the OD, assembled overall width and diameter of the ball itself....trying to figure out if they'll work in my flex joints.....they're just too noisey!
Called Currie and they weren't very accommodating......even called Energy Suspension (they make their bushings) but, they couldn't give out "that info" ???
Don't really want to drive all the way to Corona just to measure a bushing, so.....if anybody could help me out it would be much appreciated.
Thanks,
Hans
I have replacement ones in the shop. I'll go measure them for you.
OD - 2 3/16
ID - 1 3/16
Depth to lower shoulder - 5/8
Depth to upper shoulder - 11/16
Depth to top of the lugs - 13/16
The ID has a 3/16 flat and then it tapers out to the lugs.
2 of them together is 1 7/16 wide.
Hope that helps.
Thanks!
I will measure the bushings in my spare and hope that they are compatible.....tired of all the noise transmitted!
Hans
