Old February 23rd, 2017, 07:20
Redsnake Redsnake is offline
2001 Front end popping / rattle ... but not all the time.
OK so I've read thru all the 'front / popping / rattling' threads I can find but I still can't seem to find the issue I'm having.
The front left/drivers side of my '01 XJ has a rattle or popping that comes from what feels like the front drivers side ... sometimes it feels like it's right under my feet. Here's the strange part. I don't have this pop in the morning while driving into work but on the way home I notice it almost every time I roll to a stop. It only happens when I'm coming to a stop (or that's when it's most audible and I can feel it in my feet). It doesn't do it when I drive over a bump in the road, it doesn't do it when I'm turning and seems to be only present when under 10 mph and up until I stop.
Things I have checked: Track bar bolts have all been tightened down w/my impact or breaker bar to assure they're tight. I have Black Magic front brakes w/ Centric rotors (~ 2 years old) and when I did those the caliper bolts were greased and there were no apparent grooves where the pads ride. I've visually checked and can't find any cracks or broken bolts. Running Brown Dog Motor Mounts and a fresh Auto Tranny Mount. I replaced the OE XJ tie rod w/one from a Grand Cherokee ~ 1.5 years back and it looks good. I also think I've replace both front Hub Assemblies (can't remember for sure as I've replaced them on both my boys vehicles and all 3 XJ's & Dodge Ram we've had in our family rotation over the past few years... seems like a VERY common issue on 4x4's with over 100K miles). Replaced Sway Bar & end link bushings w/ Energy Suspension bushings.
Things I haven't checked but look ok: Power Steering spacer / bracket (the Aluminum one that fits between the gears and frame rail that tends to crack), Control Arm bushings (they look ok but I know that's not always the case). I have KYB shocks on the front that were installed ~ 3 years back so perhaps those could have gone bad... (I haven't pulled the shock off to check rebound and it doesn't appear that any shock oil is leaking). Haven't pulled the front driveshaft off to see if the noise is gone... simply because the noise isn't there all the time.
My XJ has 162K miles on the odometer and any tips or things to check would be appreciated. I hate to just throw parts at my rig to try and solve issues.
On the want to add list is the BoostWerks's steering brace, JCR steel steering box spacer, New front Lower and Upper Control arms ... although I'm not sure when those will be in the budget. Thanks for any suggestions and tips. Hopefully I'll have a chance to check this out over the weekend.
Old February 23rd, 2017, 08:35
90xj06's Avatar
90xj06 90xj06 is offline
Re: 2001 Front end popping / rattle ... but not all the time.
check to make sure the exhaust isnt hitting anything.
Old February 23rd, 2017, 08:45
Hmmm... hadn't thought of that. I did replace the Header and Pre-Cat exhaust this past Fall and have been experiencing an exhaust leak that needs to be tracked down... could be something is rattling on the exhaust as it gets up to Operating temps.
Old February 23rd, 2017, 08:54
RCP Phx RCP Phx is offline
It sounds like CA bushings to me! How much lift/what arms?
Old February 23rd, 2017, 08:59
I've been thinking the same thing... No Lift and still running the OE Upper and Lower Control arms as far as I know. I'm not the original owner and got it with ~ 92K miles from a used dealership.
Would you think Upper or Lower CA bushings... or perhaps both?
Old February 24th, 2017, 22:51
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Considering the rubber bushings are 16 years old with 92k, a bad CA is definitely on the list of things to check.
The three times i've encounter this problem, it was a worn or loose UCA.
Pulling the CAs, for inspection or replacement, isn't that hard, as long as you only remove one CA at a time.
I keep a come-a-long handy, in case the axle needs to be nudged forward or backwards a bit. It's a useful tool for the solo mechanic.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, 4.6L Russ Pottenger. stroker, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Old February 27th, 2017, 06:51
Thanks for the info guys!! I had a very busy weekend so I wasn't able to mess w/my XJ. Also, new Control Arms have been on my 'to-do' list for a while just because I wanted to add some clearance for wider tires, but this gives me an excuse.
To add another question for this topic... would it be OK to change just the Lower Control Arms or is it much better to swap in new Upper and Lower Control arms at the same time?
Old February 27th, 2017, 11:49
lazyxj's Avatar
NAXJA Member #1310
Many of us have slowly modified the suspension. Adding either upper or lower is OK, both is better. I first changed the LCA to allow for wider tires.
As the lift increase, the UCAs were changed, to better adjust the alignment and wheelbase.
Old February 27th, 2017, 15:35
Thanks again... now the 'what to buy' and 'which is the right LCA for me' comes into play. I've been looking at Core4x4, Ironrockoffroad, JKS and Metalcloak...
I do almost no offroading in my '01 XJ currently so I don't need the absolute best, but if I'm going to spend say $200 on a set of LCA's... why not spend an additional $50-$100 to get something that much better. Decisions Decisions Decisions...
Old March 21st, 2017, 09:06
So I was able to swap in some Teraflex Monster LCA's this past weekend and while they are beefy and this helped tighten up the feel of the jeep there's still that rattle / pop noise as before. I'm still on the hunt to fix it up but the LCA's were apparently not the culprit here.
I think my next thing to check is the steering box spacer and then look a bit closer for any frame cracks (which I've not been able to find) ... perhaps it could be my brake pads rattling but since I have Black Magic pads and centric rotors, I'd hope that's not my issue.
Here's the LCA's...
Old March 21st, 2017, 17:07
Bobbie's Avatar
Bobbie Bobbie is offline
Inner fender
Old March 22nd, 2017, 05:59
Originally Posted by Bobbie View Post
Inner fender
Are you saying this subject is like beating a dead horse and has been asked/answered many times before? I'm not sure I've ever heard that the inner fender can cause rattling / popping... but I'd like to hear more if this is the cause so I can fix it.
Old March 22nd, 2017, 07:11
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
One thing that will cause a popping noise (though unlikely on a stock-ish rig) is the spot welds failing on the inside lower control arm bracket(s). There is a gusset that is spot welded to the frame rail that runs at an angle down to the mount. These welds can pull out taking some of the frame with them. They can also Crack where they are bent at an angle next to where they are attached.
For me that was the initial point of failure for the entire bracket. I've wheeled my rig pretty hard at times over the years so it wasn't too terribly surprising. I wouldn't think that it would be a problem a rig that sees only street and light trail use only.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 D-44 Stock-ish
SoCal Chapter VP
Last edited by Bent; March 22nd, 2017 at 07:15. Reason: Truth In Posting Regulation compliance.
Old March 24th, 2017, 01:25
lazyxj's Avatar
NAXJA Member #1310
Inner fender
Odd response to a subject I can't remember seeing before over the last 13 years.
What part of the inner fender can make a popping noise and how do you fix it?
Old August 22nd, 2017, 07:30
Update: Sorry I never got back to updating this post...
As it turns out, my Brown Dog Rubber Motor Mounts had taken a dump... the rubber was shot. Not quite as bad as the OE Rubber mounts do but they were bad enough. I replaced them w/ a pair of StinkyFabRacing (SFR) mounts and the rattles went away. I only found out by chance as the SFR mounts were bought to aid in the NHV that the BD Mounts had always caused. After replacing the Motor Mounts I've not had the rattle that has been pestering me for a while. Hopefully down the road this thread might help someone else.
Ping/rattle at all rpm/speed: 2001 XJ SuzysJ OEM Tech Discussion 4 August 1st, 2011 15:14
Popping all the time. 94XJSE OEM Tech Discussion 2 January 5th, 2008 04:05
Front End Rattle? oo7ravisXJ OEM Tech Discussion 7 October 12th, 2007 20:05
Front End Rattle Questions Help! sublime600 OEM Tech Discussion 6 August 13th, 2006 19:48
front brake rattle chad OEM Tech Discussion 5 October 10th, 2003 13:32
