Old August 5th, 2008, 12:58
Daedalus454's Avatar
Daedalus454 Daedalus454 is offline
Oil pressure gauge malfunction or oil pressure spike?
My oil pressure gauge has been acting up recently, it normally runs about 45 psi or so. Sometimes while I am accelerating it will peg out at max pressure, when I lift my foot off the gas it drops down to 60psi or so. At first I thought there was a problem with my sending unit, but wouldn't that just drop it to zero rather than max? Perhaps the problem is with my oil pressure relief valve?
I'm running a 100% stock motor with ~176,000 miles on it. I'm running the new "Triple Protect" Shell Rotella T 15W40 with a Wix filter. I have a leaky rear main seal and some valve clatter when it's hot.
Old August 5th, 2008, 14:24
smcdonaldaz's Avatar
smcdonaldaz smcdonaldaz is offline
Re: Oil pressure gauge malfunction or oil pressure spike?
Change the sender, that's exactly what mine did. Plus it's one of the cheapest things to try.
Old August 5th, 2008, 14:28
89CherokeePioneer 89CherokeePioneer is offline
Pressure drops with lower engine RPM, not the other way around. Exactly what my sender did is what yours is doing. Eventually it just pegged out constantly-though occasionally if I hit the sender with a hammer, it would read okay for a few minutes.
Old August 5th, 2008, 17:21
k.smith904 k.smith904 is offline
ditto on changing the sender. My oil pressure was sitting at 60 PSI at idle, so I asked the good folks at and this is apparently a common problem. Picked up a new unit at Autozone for $25, took 10 min to install. Very easy fix, and if not, its a cheap place to start.
Also, check your cat converter, might be clogged.
Old August 5th, 2008, 21:45
Matthew Currie's Avatar
Matthew Currie Matthew Currie is offline
NAXJA Member #760
Post -91 senders peg up when they are disconnected or open, rather than dropping to zero. If the problem is intermittent, you might try just cleaning the contacts first. If no help, then replace the sender.
Old August 5th, 2008, 22:09
lawsoncl lawsoncl is offline
Huh?
oil pressure gauge Kiefer316 OEM Tech Discussion 8 March 31st, 2008 21:45
Oil pressure gauge mudslinger4x4 OEM Tech Discussion 2 February 5th, 2008 08:34
oip pressure gauge help lenny OEM Tech Discussion 5 August 1st, 2005 16:07
Stock oil pressure gauge ? blaisetd OEM Tech Discussion 1 March 14th, 2005 10:26
Sudden (& apparently permanent) spike in oil pressure Churchlady OEM Tech Discussion 39 June 7th, 2004 19:06
