Old November 27th, 2006, 00:58
twisted_ed's Avatar
twisted_ed twisted_ed is offline
Pressure switch that closes once a minimum pressure is reached??
I am looking for a switch to add to my custom ARB compressor system, in which the switch would close completeing the circuit once the pressure has reached the lockers operating presure allowing me to activate it then, sort of a fail safe and somthing to do just for the fun of it. Anyone come accross anything like that?
Again this is a switch that closes and stays closed once the minimum pressure is reached, it does not open unless the pressure drops below the minimum, so it is NOT the kind of switch that cycles air compressors on or off
Old November 27th, 2006, 08:10
BrettM's Avatar
BrettM BrettM is offline
Re: Pressure switch that closes once a minimum pressure is reached??
that would be very simple to make with a normal pressure switch and a relay to reverse the function
Old November 27th, 2006, 11:10
5-90's Avatar
5-90 5-90 is offline
Either that, or just look for a Hobbs switch. They're typically used as "fail-safes" to cut ignition or fuel delivery if engine oil pressure drops below a preset level, but I'm sure there are "air" versions as well.
Then, you can use the switch to drive an indicator light.
Or, you can just plumb in a gage, and put a "minimum redline" on the gage face. This would have the additional advantage of letting you know when the compressor isn't working up to scratch, and give you some early indication of that little factoid... I hate idiot lights.
5-90
Old November 27th, 2006, 11:34
KarlVP's Avatar
KarlVP KarlVP is offline
Like this? http://www.viaircorp.com/90108.html
You can find them in different pressure ratings. The one I have is 150 off 85 On. Can't remember where I got it though.
Old November 27th, 2006, 15:14
twisted_ed's Avatar
That is a compressor cycling switch, what I already have.
Old November 28th, 2006, 08:32
Gerr's Avatar
Gerr Gerr is offline
ok youve got me wondering what we have at the shop that does that same thing you asking about. We use some air over hydrolic systems on our cranes and they will not function or allow you to activate the system till a certain pressure is reached (not sure how much it requires though) We also have a alarm system that has a tone that lets you know there isnt enough pressure in the air system Im wondering if that will wok for your application, Ill tear some spares apart in the next few days and see what I find. I love rain days
Old November 28th, 2006, 11:14
Gerr's Avatar
Check this link http://www.alliedelec.com/Search/Pro...SKU=611%2D3026
while your there take a look at the catalog link on the page for more info and a few differnt options. the switch comes in both normally closed and normally open or dual circuit.
5-90 was once again right on the money (and I found out its the same switch we use on our crane systems and on big rigs as well)
Pressure switch wiring for OBA 1996cc Modified Tech Discussion 14 October 31st, 2006 22:03
pressure switch jeepnuts311 Modified Tech Discussion 4 August 30th, 2006 10:26
low pressure cut off switch on ac bradmoody OEM Tech Discussion 12 May 29th, 2006 14:00
Oil pressure switch for swaped-in 3.4 85Chief Modified Tech Discussion 9 December 13th, 2004 00:22
A/C low pressure switch georgemu OEM Tech Discussion 1 March 5th, 2004 16:31
