Old January 8th, 2018, 08:24
xjabyss xjabyss is offline
universal cat help
has anyone replaced their exhaust with 'direct fit" downpipes and a universal cat? the downpipes has a strange flange configuration, and 2.5" adapters don't fir the Cat inlet.. any help greatly appreciated
Old January 8th, 2018, 15:45
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: universal cat help
First thing, for even mildly technical questions you need to completely describe the vehicle in question. What year, engine, transmission, transfer case, options, modifications, etc.
Over the years XJ Cherokees had different engines, transmissions, and computer ignition systems, so the correct answer to most question will vary based on the model year, and the optional equipment, and/or modifications installed.
Next you need to explain why you wanting to use non-standard exhaust and cat converter parts. Do you have links to, or part numbers for, the stuff you are looking at ?
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
universal joints jamesbtaylorjt Modified Tech Discussion 2 October 20th, 2011 09:08
XJ Universal Flares ?? MoparMatt77 Sierra Chapter 3 December 14th, 2010 23:25
HD 1/4'' Universal LCA brackets Twisted_Dakota Red River Chapter For Sale/Wanted 0 August 10th, 2010 19:22
Universal Joints mknack Modified Tech Discussion 8 October 19th, 2009 12:17
D30 Knuckles - Universal fit..?? XpedientJ OEM Tech Discussion 13 August 7th, 2009 15:17
