Old January 3rd, 2018, 09:14
chickenbot chickenbot is offline
Autolockers and a manual transmission DD
93 XJ AX15 NP231 D30HP C8.25
I'm looking to put lunchbox lockers in my DD but it a manual trans and was wondering if anyone out there has done the same or is it a bad idea. Should I just stick to doing it to 1 axle or is both ok?
Old January 9th, 2018, 06:26
Re: Autolockers and a manual transmission DD
bump
Old January 9th, 2018, 18:23
trippled trippled is offline
What are wheeling? Do you need both locked? If not, I'd start with the front axle. It's not too noticeable on the street but a huge benefit on the trail. If you need more then do the rear but you will notice it a lot more and may have to adjust your driving style a little if it bugs you.
Old January 9th, 2018, 20:06
themauler's Avatar
themauler themauler is offline
I have lunch box lockers in mine front and rear with an ax15. Lunch box lockers by design have 1/4 rotation of slop in them before the driveline engages. This basically forces me to coast through u turns on the road and in a parking lots or the jeep starts to buck like a mofo. Besides that it is do-able.
Lunchbox lockers were one of my most favorite upgrade. Do the front. If you need more traction then throw one in the back. The clicking and banging is normal until they "break in"
Better yet you decide they aren't for you, keep your old spider gears, and just take the locker out and put the spider gears back in.
Nick Maul,
Just want to build something that won't break on the trail
Old January 10th, 2018, 07:43
RCP Phx RCP Phx is offline
If you get something like a Power-trax No-slip you won't have any noise!
Old January 10th, 2018, 08:06
I don't know what kind of wheeling yet. But I do want to be prepared for anything. Its looking like I should just start with the front. I'm looking at TORQ Locker TL-13027 Dana 30. Noise doesn't bother me because I just got with the old saying "to fix any noise in your car, just turn up the radio."
Old January 10th, 2018, 11:56
sinat01's Avatar
sinat01 sinat01 is offline
I was contemplating doing the rear axle first. 99 4.0 AX15 on 33s just figured offroad the rear being locked would help more. but im in the same boat with trying to decide.
Old January 10th, 2018, 12:43
I'm on 33s as well but with no lift.. Its in the works. I've noticed there aren't a lot of ax15s out there
Old January 10th, 2018, 15:15
In general, if you only have one locker, the front is usually more beneficial!
Old January 10th, 2018, 15:55
smccollamjr smccollamjr is offline
It depends on the kind of wheeling you do. If like crawling on rocks the locker in the front is better because it helps you climb up on rocks. If you do a lot of steep hill climbs where the front unloads youíre better off having one in the rear where most of your weight is. On steep side hills a rear locker can make your rear slide down the hill if itís slick.
Old January 10th, 2018, 20:50
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
I have an Aussie locker in the front of my 96 with a 5 speed and daily drive it with out issue.
It is noisy and somewhat jerky on sharp turns.
I was real noisy off road but quieted down after about 1500 trial miles. I mainly do expedition stuff solo so I don't really beat on it to hard.
When money and time allow I am thinking about putting one in the rear. Might go tru trac though if I am feeling ambitious
Old January 13th, 2018, 07:32
xj92's Avatar
xj92 xj92 is offline
I had a 93 XJ with an ax15 that I had Detroit Lockers in the front and rear, D30 front, C8.25 rear. I didn't notice it on the street with the front locker, but once the rear was installed it was definitely noticeable. I had to be careful on the highway around turns at speed, I had to maintain steady throttle. If I got on and off the throttle it wanted to go one direction or the other. You also notice it in parking lots and other places. I won't do a rear auto locker again with a stick shift and short wheel base on a DD.
WTB Manual Transmission Stallacrew SEC For Sale / Wanted Forum 1 May 24th, 2009 17:16
manual transmission Ritter4.0 North Atlantic Chapter 4 December 22nd, 2008 17:46
If you've got a D44 and manual transmission Menzenski OEM Tech Discussion 5 July 4th, 2006 20:32
