Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
1989 Renix Injector swap
Currently have a mostly stock 1989 Cherokee, about 205,000 miles on it with AX15 behind it. Wanting to upgrade injectors to 4 hole. All research if found says to get part # 0280155703 - but with different flow rate? Would these work?
#2
Re: 1989 Renix Injector swap
#3
I used the 19 lb/hr injectors in my RENIX Jeep after one of the stock injectors developed an external leak.
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile... |
#4
If I use Bosch 0280155703 :
Is it too much fuel? Too high pressure rating? Will the piston get hot spots that will eventually blow the rings? Has anyone put these in an 89' ? I search for upgraded injectors and find websites that say these are the ones I need, but when looking to buy, they say to use 710's instead. Last edited by DarkoShadow; January 1st, 2018 at 19:46. |
#5
#6
Ok, think I found enough info to try this all out. I'll comment back once if installed an run a tank or 2.
#7
I just installed some today in my 90. I installed 746s that i got form a guy on another forum.
#8
Found this for others wanting to swap injectores...
https://www.google.com/search?q=inje...raseYNiC-zzQM: Last edited by DarkoShadow; January 5th, 2018 at 19:47. |
Thread Tools | |
Display Modes | |
Renix Injector(s) | edgreeson65 | SoCal For Sale | 10 | August 31st, 2015 07:21 |
renix injector seal kit | slowrider | OEM Tech Discussion | 6 | October 5th, 2013 19:36 |
No injector pulse, 1989 4.0 MJ | xjtrailrider | OEM Tech Discussion | 14 | June 4th, 2011 19:57 |
Renix injector swap issues | etaoin2 | OEM Tech Discussion | 23 | July 8th, 2010 19:33 |
renix stroker....injector? | slabelle67 | Modified Tech Discussion | 1 | February 14th, 2007 17:49 |
