Old December 21st, 2017, 17:42
jeep ride's Avatar
jeep ride jeep ride is offline
Unhappy Frame rust
Found a rust hole about 8 inches long where the bump stop was bolted on does anyone make a repair frame rail that I could have welded on?
Old December 22nd, 2017, 07:00
trippled trippled is offline
Re: Frame rust
You could get a set of rear frame stiffeners and then patch any remaining hole with more plate. That's probably the route I would take if the surrounding area is still decent.
Old December 22nd, 2017, 08:35
jeep ride's Avatar
Re: Frame rust
That's what I was thinking do you know if they would all the way to the rear bumper the rust starts where the frame starts to curve up over the rear axle and goes about 8 inches or so over rear axle
Old December 23rd, 2017, 07:40
BenWheelin BenWheelin is offline
Re: Frame rust
I've never seen one rust there. I've seen the top of the rails where the floor disappeared and the frame still looked new, but never rust on the actual frame. Maybe it's the desert.
I'd suggest you take a hammer to your underside and investigate. Chip out the obvious part and see how big it gets. Pick at any bubbling in the paint you see. You're liable to find damage too extensive to fix.
Old December 23rd, 2017, 10:55
jeep ride's Avatar
Re: Frame rust
Thats a good idea about the hammer I posted pics on the naxja.org facebook site I cant post to this site though Thanks for the tip
Old December 23rd, 2017, 18:35
Re: Frame rust
Wear glasses. Have fun.
Old December 23rd, 2017, 20:08
jeep ride's Avatar
Re: Frame rust
Wish I would have wore glasses while I was cutting the exhaust system off that was when I found the rusted frame
Old December 26th, 2017, 15:53
jeep ride's Avatar
Re: Frame rust
Got my exhaust fixed found a rust hole right rear outside frame rail9
Old December 26th, 2017, 17:55
Re: Frame rust
You could cut panels out of another one and weld them in, followed by plate.
Old December 26th, 2017, 18:13
jeep ride's Avatar
Re: Frame rust
I was thinking about iron rock rear frame stifners and have them welded on
Old December 29th, 2017, 12:21
jeep ride's Avatar
Re: Frame rust
Ended up dropping off xj at a local weld shop for some ( frame) repair
Old January 4th, 2018, 19:13
jeep ride's Avatar
Re: Frame rust
Got the frame repaired
Windshield frame rust garr OEM Tech Discussion 5 October 2nd, 2013 21:45
Windshield Frame Rust Repair Lurch1980 Paint and Bodywork forum 8 December 13th, 2011 20:44
windshield frame rust 1990JEEPXJ Paint and Bodywork forum 5 March 16th, 2011 13:07
Dealing with a bit of windshield frame rust clunk OEM Tech Discussion 4 January 9th, 2008 20:40
Windsheild frame rust repair bzdel2441 OEM Tech Discussion 6 September 6th, 2005 06:10
