Old August 15th, 2017, 06:52
burntkat burntkat is offline
NAXJA Member #1145
Re: New guy build-The Family Truckster
Yeah, neither will my son's, at least not till it's far from a DD and it's his problem if he screws it up, not mine.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old August 21st, 2017, 09:17
SByota SByota is offline
A big day for the "Family Truckster". The front suspension design is done. Everything cycles like it should and nothing crashes into anything else. Track bar and drag link and within .25" in length and are sitting at the same angle. Cycles 10" with room to spare on both ends, which is what I was shooting for. Caster is 5 degrees and ride height and 12 at full bump. No bump steer and the caster gain should make it really stable.
Lots of welding and fab still to go, but the hardest part of the front is done.
Old August 21st, 2017, 10:07
VAhasnoWAVES VAhasnoWAVES is offline
is this a go fast rig or crawling rig?
Old August 21st, 2017, 10:25
More go fast than crawling.
Old October 19th, 2017, 16:38
Summer has been super busy for me. Family vacations, mandatory overtime, and life in general has been keeping me out of the garage. Got back at it today, finished up the frame side track bar mount. I'm never 100% happy with my welding, still working on being super consistent with my bead size and profile. I have no doubt that parts are glued together good though.
I also copied the great ZT Fab's toolbox welding cart. I should have doe this years ago, it is so nice have all my welding and metal fab stuff in one place.
Old October 21st, 2017, 22:05
trippled trippled is offline
That TB mount is sexy. Great work!
Old October 22nd, 2017, 08:45
Thanks! I have a silly amount of hours into it. No wonder this build is taking forever!
Old October 22nd, 2017, 20:26
NAXJA Member #1145
I wouldn't worry about your welding. That's professional level work.
Old November 9th, 2017, 03:18
Burned in the control arms today. One step closer!!
Old November 13th, 2017, 19:58
Burned in all the suspension links. All the heims threaded in nice and smooth!. Painted and assembled all the links/spindles and stashed them in the shed. Whipped up this quick steering box spacer out of 3/16" plate and .250 wall DOM. TIG welded for style points!.
Old November 13th, 2017, 23:04
Heavyopp Heavyopp is offline
Photobucket did me dirty. I'm on the search for a new hosting site. Any suggestions.
Who did you end up with as a host?
Great thread, wish I could see the beginning
Old November 14th, 2017, 01:27
Imgur, no cost and works good.
Old November 14th, 2017, 06:11
XJsportG's Avatar
XJsportG XJsportG is offline
SouthEast #4328 (RVA)
Are you resizing your photos before uploading?
RVA
Old November 14th, 2017, 15:34
Yes, to message board size. 640 x 820 I think? The originals are HUGE!!
Old November 27th, 2017, 21:32
I started working on reinforcing the bump stops, shock mounts and front end in preparation for paint and final assembly. I cut of the bottom of the stock bump stops and sleeved them with 1.75” DOM. The new bump stop tube runs up into the engine bay and is attached with a 3/16” plate. I will tie the new bump stop tube into the top of the shock mount. The new bump stops have nuts welded (pictured) inside them for short urethane snubbers. I will use prothane coil inserts with a UHMW rod inside as the actual hard stop.
I cannot wait to be done welding on the thin galvanized sheet metal, it’s terrible to work with.
Family centered overland build overxjland Adventure Forum 5 February 25th, 2016 11:41
Tom95YJ's Family Wheeler Build ... Tom95YJ Modified Tech Discussion 80 March 2nd, 2013 23:25
Family wheeler build XJdriver Arizona Chapter 23 December 24th, 2012 12:16
The Family Build CarolinaCrawler South East Chapter 18 October 22nd, 2012 10:19
