Old June 29th, 2017, 16:32
SByota SByota is offline
Re: New guy build-The Family Truckster
Soaked my WJ knuckles in apple cider vinegar for a few days to knock the rust off. Burned in the bearing spacers today. I started working on the double shear for the tie rod and drag link too. Not the most perfect welds, but I think they will hold.
Old June 30th, 2017, 16:22
Old June 30th, 2017, 16:31
Old June 30th, 2017, 20:27
GordoSmasho's Avatar
GordoSmasho GordoSmasho is offline
Sierra Chapter Treasurer
None of your pics are working bud
Old June 30th, 2017, 21:01
Photobucket did me dirty. I'm on the search for a new hosting site. Any suggestions.
Old July 1st, 2017, 02:19
The welding of the knuckle spacers. Its a bummer about the old pictures. Ill try yo post the greatest hits.
Old July 6th, 2017, 16:31
Did some more work on the lower control arm mounts today.
Old July 7th, 2017, 13:52
burntkat burntkat is offline
NAXJA Member #1145
While the welds are beautiful on the lower mounts in that last post, I wonder if you wouldn't be better welding a fishmouth plate to the unibody, then welding to that?
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old July 7th, 2017, 17:21
I agree 100%. It's hard to see in the pictures, but I installed full length frame reinforcement plates from ruff stuff before I built the lower control arm mounts. So no need for another fish mouth plate. Plenty of beef.
Old July 10th, 2017, 05:57
NAXJA Member #1145
FYI, apple cider vinegar is not needed.
Plain old white distilled works just fine. I've used it many times.
Old July 10th, 2017, 05:58
NAXJA Member #1145
Ah, it's a thing of beauty.
I am looking to use those exact plates on my 90 and my son's 97. GREAT company!
Old July 14th, 2017, 23:46
More work on the WJ knuckles. Double shear for all the steering joints.
Old July 18th, 2017, 06:09
NAXJA Member #1145
Beautiful.
Those knuckles are cast iron, right? How are you preheating/quenching?
Old July 18th, 2017, 08:25
Beautiful.
Thanks. I did a lot of reading on various forums about welding to knuckles/center sections. They are a lot of opinions on what is the "correct" way to weld mild steel to these parts. Here is what I did.
Soaked the knuckles in apple cider vinegar to clean the rust off. This did a great job of getting them clean/rust free.
I used an old set of unit bearings to secure the spacer for welding. I pre-heated the knuckle with a MAPP gas torch to about 300 degrees then tacked them up with using my TIG welder at about 180 amps with 3/32" ER70S2 filler. I pulled the unit bearing off, then welded them up. I alternated the sides when welding to spread the heat around.
I welding them using 2 passes, and lots of post flow to prevent "hot cracking" from the two different materials cooling at different rates. It welded pretty smoothly. I let them cool in open air on my work bench. It took about 5 hours for them too cool completely. You can see a little bit of garbage from the knuckle in the surface of the welds in the picture. I'm happy with how they came out.
Old July 18th, 2017, 11:04
NAXJA Member #1145
They look good. I'm curious how you managed temps- specifically how you determined the initial preheat temp- maybe an IR non-contact thermometer?
Also, more concerned with the dual-sheer bracket welding. The spacers shouldn't be terribly crucial welds, as they are held to the knuckle by the unit bearing throughbolts to the knuckle.
The dual-sheer are MUCH more crucial, as they have no reinforcement whatsoever other than themselves- they are the reinforcement.. and if they fail you're going to have an entirely too-interesting and exciting day.
By no means mean any criticism- I'm simply trying to add some tricks to my limited bag of tricks.
Family centered overland build overxjland Adventure Forum 5 February 25th, 2016 10:41
Tom95YJ's Family Wheeler Build ... Tom95YJ Modified Tech Discussion 80 March 2nd, 2013 22:25
Family wheeler build XJdriver Arizona Chapter 23 December 24th, 2012 11:16
The Family Build CarolinaCrawler South East Chapter 18 October 22nd, 2012 09:19
