Old September 26th, 2017, 19:21
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
Re: Project Unicorn - a light duty trail rig
I may have missed a post, is there a reason that you didn't mount the sensor in the stock location? I've never had mine read incorrect by more than a few degrees.
88 MJ on 40's. 98 XJ on 35's. 98 Dodge, 52psi of boost. 94 Miata LS4. 70 Buick GS455. 01 Harley, been to 46 states. 05 KTM, 576cc. 06 Husky, girls need bikes too. 2011 R6, girls need sport bikes too. 99 Toyota Avalon, daily. 97 Miata, girls apparently need miatas too.
And everything fits in the garage!
Originally Posted by mako my day View Post
Johnx is #1
Old September 26th, 2017, 19:34
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Ignorance?
Where's the stock location?
Old September 27th, 2017, 16:20
Just Differentials's Avatar
Just Differentials Just Differentials is offline
Differentials and Axles!
I just have to say...what a beautifully clean XJ you have!!! Definitely a unicorn. Kudos!!
Old September 27th, 2017, 16:54
Kittrell's Avatar
Kittrell Kittrell is offline
Ignorance?
On the crossmember.
Old September 27th, 2017, 20:44
ehall's Avatar
ehall ehall is offline
Yeah it goes on the front crossmember.
Temperature should be measured in the shade and wind. You want all the heat transferred so that its completely ambient reading.
my '91 beater rebuild
Old September 27th, 2017, 22:52
cal's Avatar
cal cal is offline
That's pretty close to where it started out, but when the Jeep gets back from aFe I will crawl under and look at it closer.
I may look for a different sensor that's easier to mount, too.
Old September 28th, 2017, 10:07
ehall's Avatar
ZJs have a small little pigtail extender on their sensor, just a few inches long. I use it on my XJ because its easier to mount to the sheet metal.
Old January 4th, 2018, 00:29
frijolee frijolee is offline
Been a while... What's up with the unicorn?
Old January 4th, 2018, 04:07
cal's Avatar
cal cal is offline
Part collecting. Expect rapid movement and updates after KOH.
Old January 5th, 2018, 19:00
cal's Avatar
cal cal is offline
Now that I'm home.
So I haven't been idle on this, just collecting lots of parts.
Plan is 4" lift
deaver G9's @ 2.75" + shackle relocator + shackle
Pac 4" jeepspeed coil
SFR 3 link
HP30 front
Motive Grip Pro limited slip
4.10 gears
WJ converted (same trackbar setup as 4643)
Ten Factory shafts
Black Magic Brakes
XJ44 rear
iron rock truss
4.10 gears
Ten Factory shafts
8.8 backing plates with TJ 44 brakes and black magic pads
285/75/16 Falken Wildpeak MT's on Procomp 16x8 wheels
Bishop Buehl 4.7 stroker, kind of middle of the road build
Atlas 3.8
Bilstein 5100's for now, may do 7100 shortbody's later.
I have almost everything now, I just need to pick up a few odds and ends and make the time to do it. I know Dallas is chomping at the bit to get the 3 link kit buttoned up, I may leave it with him to start working on it but I won't be able to finish things until after KOH.
Old January 6th, 2018, 09:21
Goose_XJ88's Avatar
Goose_XJ88 Goose_XJ88 is offline
Interesting, I didn't realize deaver made leaves shorter than 4.5"
88 XJ Laredo 8" RE SA, drop brackets, 35s D30/44 4.56, AW4, 242, 7100s, Loganís ft winch bumper, JCR swing out tire carrier, JCR sliders, 96 booster, 97+ mirrors & console (FOR SALE)
99 XJ Limited, AW4, 242, Colombia Edition WJ Seats, Stock. Future 4.5" lift, TnT LA, 33s armor, 231 SYE, D30/44 4.56, rear locker, etc
93 XJ 2 Door AX-15 D30/8.25 3.55 swap, (FOR SALE)
92 MJ AW4 2wd, 97 mirrors. Future 4wd swap, 242, MJ 44, Eliminator Roll bar, Bucket seats, 97+ console
Old January 6th, 2018, 09:53
cal's Avatar
cal cal is offline
Deaver makes whatever you want, you just have to ask. These were the standard G9s that they lowered for me.
Old January 6th, 2018, 11:58
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
NAXJA Forum Addict
Interesting. Been thinking of going deaver and I think your plan is more in line with what Iíd want
John V.
01 XJ Sport 2 door 5spd/4WD- 4" lift, 35" BFG ATs, JCR bumpers, Rubi 44, Ford 8.8, 4.56's, ARBs
Old January 7th, 2018, 09:57
Heavyopp Heavyopp is offline
I'm liking this idea too -- I already have the pac 4" springs -- like you I'm just acquiring parts at the moment
What shackle components are you going to use? Made by who?
New Project 89 XJ Unicorn zachxj01 North Atlantic Chapter 9 May 26th, 2016 17:39
Anyone use OME LIGHT DUTY leafs? djlarroc Modified Tech Discussion 19 August 10th, 2013 19:39
Project:Unicorn SAMSET Midwest Chapter 27 September 28th, 2012 11:58
WTB light duty truck tires XJwheelman NAC Classifieds 0 June 5th, 2011 15:41
Some light duty mods for a camping XJ terryd Modified Tech Discussion 10 January 11th, 2008 17:50
