Old January 5th, 2018, 09:13
racer32's Avatar
racer32 racer32 is offline
Re: Projext "V8 XJ" Build
Originally Posted by PhotoJared View Post
Could the mismatched injectors in the tune cause it not to start?
This shouldn't be an issue. What injectors did you use?
Old January 5th, 2018, 12:05
PhotoJared's Avatar
PhotoJared PhotoJared is offline
Originally Posted by R6TeXJ View Post
When you say it wont start, does your starter kick it, does the motor try and turn over, or is there no noise?
It turns over just doesnt fire. Not sure if its a fuel issue (fuel is getting to the rail), or a spark issue
The stock LS6 injectors.
Old January 6th, 2018, 17:27
cleenrob's Avatar
cleenrob cleenrob is offline
im guessing just a fuel issue.
tough call on the new jeep thing. im thinking of selling mine so i can buy a house and then building an lq4 MJ or a c10,
(jetta still commandeered by my mom, and i bought a 14' scion tc for my commute to work)
Old January 6th, 2018, 17:37
PhotoJared's Avatar
Yea I'm going to pull the fuel rail to see if the injectors are actually spraying.
The new Jeep thing will just simplify this swap a lot. I'd build an aftermarket cluster which will also be really helpful.
Old January 6th, 2018, 17:48
cleenrob's Avatar
factory 96 and down gauges are pretty easy to re use in a swap, no computer needed so its just a matter of plumbing the jeep sensors into the v8
Old January 7th, 2018, 22:00
racer32's Avatar
Do you have good fuel pressure?
That is why I went aftermarket gauges on mine. Although I wish I would have saved up for Autometers and not bought those shitty Intellitronix gauges.
Old January 8th, 2018, 00:40
PhotoJared's Avatar
Iím fairly certain I do. I pulled on of my fuel lines and gas squirted all over. I know thatís not scientific lol
Old January 8th, 2018, 10:01
indian's Avatar
indian indian is offline
If you have fuel and spark the engine has to start.
Check if you have spark. (fuse, cables, coils...)
Old January 9th, 2018, 13:28
burntkat burntkat is offline
NAXJA Member #1145
Not necessarily. This presupposes that ignition and mechanical timing are correct. I'd verify those.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old January 10th, 2018, 22:17
PhotoJared's Avatar
So some changes are happening. I'll update in about a week or so
Old January 11th, 2018, 00:32
PhotoJared's Avatar
Sorry for the cliff hanger. Its good changes happening.
I hate cliff hangers too.
Old January 21st, 2018, 19:29
cleenrob's Avatar
sooooo its been a week or so
Old January 22nd, 2018, 16:45
PhotoJared's Avatar
Oh shoot I kind of forgot i posted this!
Its still not ready, but I'm buying a new XJ.
99 XJ
37x12.5x17 Goodyear MTR tires
4.86 Gears
Currie Hi-9 Front Axle with Detroit TrutracCurrie
HD 9+ Rear Axle with ARB air locker
PSC Hydro assist
Low8point interior roll cage
5" Lift Deaver front springs
Deaver rear spring pack
So I think I'm going to swap the LS into this Jeep and the 4.0 into the red Jeep.
Old January 22nd, 2018, 16:52
PhotoJared's Avatar
Duplicate
Old January 22nd, 2018, 20:01
ehall's Avatar
ehall ehall is offline
Great pic
my '91 beater rebuild
BUILD: My 1987 "Wagoneer" XJ Limited Crist Clapper OEM Tech Discussion 275 February 5th, 2018 15:59
Troy's "I need to quit working on my wife's Jeep" build troy5118 Midwest Chapter 64 November 28th, 2017 23:09
my "wannabe jeepspeed" grand cherokee build grandrunner JeepSpeed, Prerunner and Competition Tech Forum 157 July 1st, 2014 04:48
Project Jericho Stroker build. "The Craigslist Homerun" jwittlock Modified Tech Discussion 36 December 29th, 2012 03:14
98 XJ Sport, lifted "Project Impound Build" XJ&CHZ4ME MWC For Sale/Wanted Forum 5 May 20th, 2011 13:19
