Magus2727
- Draper, UT
I am trying to figure out what ends to get for a New Tie Rod that I will be buying. I will be getting the JKS HD Tie Rod so it has the same right hand and left hanf threads. these are what I am looking at when ordering.
The LH or RH stand for right hand or left hand threads right?
but I am confused with the "At Connecting Tie Rod" and the "At Pitman Arm"
I need the ends that go on a Tie Rod SO it would be a knuckle connection and a Drag link connection.
MOOG Part # ES3095R
Front Steering; Inner; LH; At Connecting Tie Rod; 4WD
MOOG Part # ES3094L
Front Steering; Outer; LH; 4WD
MOOG Part # ES3096L
Front Steering; Inner; RH; At Pitman Arm; 4WD
MOOG Part # ES3095R
MOOG Part # ES3094L
MOOG Part # ES3096L
