awspence
- Salisbury, North Carolina or NCSU
My 99 XJ has this whistle, its been getting worse lately.
It only happens after the vehicle is warm and it happens when i let off the gas, or when i am holding it at 1/4 throttle or less. The other day it did it as I came to a stop, and i got out and tried to listen ,it sounds as if the whislte is coming from almost teh back side if the engine block, i cannot tell which side. I searched and found a post from a while back that sounds similar to what mine is doing, and it was suggested that the cat might be clogged up
Does that sound right to all of yall? If so, how would i check, if i pull my cat, would i even know then? Maybe someone knows something else it could be,
I hope i can get this fixed, it gets realy annoying on the interstate,
Adam Spencer
Adam Spencer
