- MilkyWay Galaxy
I have a dillema. Haynes manual says to use 2 oz or 5 oz of limitted slip diffy fluid additive, depending on the rear end and whether it has track lock....but does not say how much to use on Dana 44 rear ends. Mine is an '87 Dana 44, rear end with NP 242 transfer case.
I have a 7 oz tube of TransX brand limited slip diffy fluid additive, and the Trans X package says to add all 7 ozs to the rear end.
What should I do? What is the risk involved of over or under using this additive on a fresh change out of diffy fluid? I am using GL-5, 1 quart of 85-140 WT plus 1 quart of 80-90 WT, non-synthetic Lucas brand, gear oil as they were out of 85-140 WT when I went back for a second quart. I have the trailer towing package and I am in a hot climate.
