Hello ,
Quick question. So I installed a flange hack n tap on a 231 mated to an ax15. I never had time to get shafts resized so I put an auto front cherokee DS in the rear and it has worked fine on the road. Yet to do any real wheeling. I don't have a picture with the DS setup I have now, but the DS has extended all the way to where just the tip of the splines are showing(maybe 1/4"). On 3.5" of lift with AAL rear do you think I will ever have enough axle drop so that the driveshaft will separate into two parts and will leave me with a problem on the trail? Does a leaf sprung rear really droop a whole lot?
TIA :cheers:
TIA :cheers:
