No power steering when turning left only
Desert4x4
Phoenix
When the jeep is cold it will turn both directions, but after it warms a little it feels like no power steering when turning left only. The steering box is a PSC. Is there a way to free the valves or fix whatever is causing this?
Could be a rotary valve problem, in the steering box.
It is not something I would attempt to fix.
I would contact PSC for advice, it's their box.
Other here do rebuild their own boxes, so maybe they have a better idea what the solution is.
Maybe the center over adjustment, the jam nut and screw on top of the box is a little tight. Mark it well and back it off a tiny bit. If it doesn't help you can return your marks to where they were.
Just an update:
So the box started binding really badly and wouldn't turn lock to lock anymore. It felt harder to turn than without power steering and I got into a position on the trail where I had to turn left and the wheel stopped at about 1/2 turn. So I forced the wheel as hard as I could and got it to urs more after a loud snapping noise.
At this point the steering was so difficult I had to use both hands to steer even on the highway. Luckily I made it the 400 miles home driving like this. Now I've replaced the box with a cheap Napa one.
