mikeyl
- yorba linda ca
well, i'm still getting the ocassional stutter while at freeway speeds on my 91. this will probly keep me from taking my rig to moab this time. i have a quick question again. as a refresher it will drop 500 rpm while running at 2500. buck and hesitate quickly and then resume 2500. i have changed, the cps/tps/coil/fuel pump (32psi at idle and holds 32psi at upper revs). the voltmeter reads steady.the plugs/cap/wires are new. the engine sports a banks header (#5) , a 2000 intake, mustang injectors.
i am beginning to think tranny. aw4/283k on it. i am wondering if it is not locking the t.c. and on ocasion tries to and i get this drop and buck.how can i test this? does anyone know what wire from the tranny computer signals the torque convertor, off the top of their head (or manual). and will disabling it cause issues (i know heat will likely increase but i want to see if this mitigates the problem). and does this sound like a possible failure mode?
thanks in advance, mike
