I did a little wheeling yesterday and we had to run up a small river. The deepest it got was a little above the hub level. Well I went home last night and everything was working, I even made a few stops where I turned the engine off as well. I wake up this morning to go to school and it wont start. It cranks and cranks but it wont catch. I took off the cap to the distributor and there is no moisture at from what I can see. I called my gfs dad who was a mechanic, he said to check the coil wire, put it a few inches away from the coil and turn it over to see if I have any arcing at all. If not I could have blown a crankshaft sensor, or shorted a wire somewhere in the engine compartment. Thanks In Advance for the help.
Deep as it got
Distributor
There is ZERO moisture in the cap.
Deep as it got
Distributor
