Old January 15th, 2018, 10:45
Dobbie Dobbie is offline
Which measure is the flare nuts wrench for front brakes line?
Hi.
just thist afternoot i was changing my front brakes on a Germany 1993 Cherokee XJ 4.0 HO
Well. imposible take off the front end rubber hoses. I only have a 10mm wrench and 9mm wrench. i guess that it is in inches, of course.
Can anybody tell me what is the measure/size, of that flare nuts wrench?
thanks guys.
David
Old January 15th, 2018, 13:21
ehall's Avatar
ehall ehall is offline
Re: Which measure is the flare nuts wrench for front brakes line?
Probably 3/8 stock, about 9.5mm equiv
my '91 beater rebuild
Old January 15th, 2018, 16:27
techno1154's Avatar
techno1154 techno1154 is offline
Correct. I too tried to fit a metric wrench. It do not fit.
Is there such a thing as 9.5MM? If it does exist it may just do the job.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old January 15th, 2018, 19:22
jeep ride's Avatar
jeep ride jeep ride is offline
13 metric line wrench
Old January 15th, 2018, 23:26
correct, 9.5 mm , 3/8
thanks
Brake Line Wrench randyf OEM Tech Discussion 12 January 26th, 2009 02:43
Question about line wrenches, flare nuts, and bleeding brakes JoshRountree OEM Tech Discussion 23 August 3rd, 2007 07:02
Flare Wrench.....SAE or Metric and others wil4thril Modified Tech Discussion 6 December 11th, 2005 12:52
Impact Wrench for hub nuts? Ghost Non-Tech / Off Topic 2 February 6th, 2004 12:24
Flare nuts on fuel system and sealing RichP OEM Tech Discussion 1 July 13th, 2003 16:00
