Old August 10th, 2005, 18:38
edmaude edmaude is offline
NAXJA Member #1368
door hinge
The lower hinge on my drivers door is not seperating as others have, but the pin on the lower hinge seems to be gone or rusted out. How can I fix this? Dealer item or make one?
Old August 10th, 2005, 19:02
Matthew Currie's Avatar
Matthew Currie Matthew Currie is offline
NAXJA Member #760
Re: door hinge
It may depend on the year. Some have pressed-in pins, that are hard to replace, and some have roll pins that are very easy. My 87 had the roll pins. You can get a pin kit from the dealer for the pressed in ones that includes bushings, I think, or, if you can punch out the old pin remnants, you might be able to get a replacement from the auto parts store. If it's a roll pin, go down to your nearest tractor store and get a 1/4 inch roll pin and pound it in. It will push the remnants of the old one out. I don't remember the length, but standard ones are either a little too long or a little too short. Get the long one, and when it wears you can just tap it down a little more.
Old August 10th, 2005, 19:05
NAXJA Member #1368
Re: door hinge
It is on a 96 so I am guessing the door might be the same config off your 87. I guess I'll call the ole dealer to find out for sure
Old August 12th, 2005, 18:25
NAXJA Member #760
Re: door hinge
My 95 has the solid pins. According to the FSm they include a bushing, so you can get the kit from the dealer that includes both a new pin and a bushing. You need, of course, to punch out the remains of the old pin, and the old bushing, first. It sounds as if it might not be all that hard to do, but I haven't tried it so can't guarantee.
Old August 12th, 2005, 19:04
langer1's Avatar
langer1 langer1 is offline
Re: door hinge
Dale Earnhart and Michael Waltrip got them at Napa.
Old August 12th, 2005, 19:14
HaleYes's Avatar
HaleYes HaleYes is offline
Re: door hinge
Originally Posted by langer1
Dale Earnhardt Jr. and Michael Waltrip got them at Napa.
Fixed
