Old April 17th, 2005, 14:29
96XJCLASSIC's Avatar
Door Hinge Pin
I am in the process of making my front door removable but have a quick question first. Is it possible to just drive the hinge pin out with a hammer and punch? It would make cutting the bottom of the hinge off alot easier when the door and hinge is removed. I can't get the sawzall in to the hinge with the door on. Major PITA.
Old April 17th, 2005, 16:19
wish wish is offline
Re: Door Hinge Pin
If you're lucky you can just drive it out. Just put a new pin in yesterday that turned into a huge PITA, but pulled the door off to make things a bit easier. I just used a torx bit clamped into the vice grips to get it to fit properly and a little patience to get it all unthreaded.
Old April 17th, 2005, 20:43
afd516's Avatar
afd516 afd516 is offline
Re: Door Hinge Pin
I used a small cut off wheel on the end of an air grinder/cut off tool. It was small enough to fit in the door hinge area with a little help from someone pulling the door open just a hair. It might work for you if you have not got the doors off already.
'97 ECU pin out?? olympicgold Modified Tech Discussion 1 March 13th, 2005 17:40
Warrior brand quick disconnects and bar pin eliminators? 90Pioneer Modified Tech Discussion 6 November 16th, 2004 22:16
4th broken spring center pin! Who makes a stronger one? JEEPZZ Modified Tech Discussion 19 January 17th, 2004 18:28
Rotating Bar Pin Eliminators BrianJr Modified Tech Discussion 5 December 30th, 2003 09:04
3" Lift install/Bent Center Pin K9Cop Modified Tech Discussion 11 August 1st, 2003 07:55
