Old April 4th, 2008, 18:20
nitrogt101's Avatar
nitrogt101 nitrogt101 is offline
Can anyone identify this axle/knuckle? Which brakes do I need?
I need to get brakes for this axle, I have no idea what year XJ it came out of. The brake and knuckle design are different than my 98. I tried brakes from an 89 and they do not fit either. What year is this from?
"J A 40567"
Old April 4th, 2008, 18:30
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Can anyone identify this axle/knuckle? Which brakes do I need?
Here is a thread that may help. Look closely at the lugnut studs in the write-up, those don't look right on your axle.
http://www.naxja.org/forum/showthread.php?t=907146
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old April 4th, 2008, 18:55
YELLAHEEP's Avatar
YELLAHEEP YELLAHEEP is offline
Regarding the lug nut studs, it's very possible they were changed due to the wheel choice the previous owner ran on the XJ. Many aftermarket aluminum wheels have thicker mounting surfaces/centers and require longer studs and different lug nuts than the factory acorn style.
Just be sure to pay close attention to bolting up your wheels to ensure that the lug nuts don't bottom out on the stud shoulders.
As far as the knuckles, I don't know - is it possible that the axle came out of a V8 Grand Cherokee ZJ? Does the other knuckle have more than one steering arm? It looks like it uses a floating caliper - the knuckles are obviously missing the caliper braces that traditionally hold the caliper/pads.
Failure is not an option...... it comes standard with every Ford.
End of Watch: MC1, 1312 & 0369....... Rest easy brothers, we've got it from here. -----
Old April 4th, 2008, 21:09
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
I'll check tomorrow during the light but it highly resembles the HP30 in my 92. I'll check the knuckles on mine tomorrow when the rain stops and it dries up a little.
Old April 5th, 2008, 17:34
nitrogt101's Avatar
Thanks, if it is the same that would solve my problem. I'm not sure if it came out of a V8 ZJ, do they use the same control arm mounts etc? If it did, I guess thats no big deal, I just need to know so I can get ZJ brakes.
That thread would help except for I threw the rotors away months ago, they were rusted and I knew I'd be replacing them. They were not cast, I know that. But I've tried brakes from the other 2 options of XJ brakes and they do not fit.
I need to know what brakes to get, this axle needs to go in!
Old April 5th, 2008, 17:56
dizzymac's Avatar
dizzymac dizzymac is offline
looks like a WJ knuckle.
Old April 5th, 2008, 21:26
nitrogt101's Avatar
The bottom knuckles in this picture are WJ knuckles, they are not the same as my axle, however how the brake mounts to the knuckle appears the same(hole spacing).
I looked at some pictures of ZJ knuckles, it doesn't look like them either.
Old April 7th, 2008, 20:05
nitrogt101's Avatar
Well I figured it out. The axle I have is from an 89 or earlier XJ with the two piece knuckles, except I don't have the second piece! Anyone have one laying around that I can buy the knuckle piece from? Or know where to get it? Dealer?
WJ Knuckle/Crossover steering and brakes MGrobe Modified Tech Discussion 38 May 15th, 2013 21:07
Identify this axle PAPXJ Modified Tech Discussion 26 February 6th, 2012 20:46
Can you identify this axle? lesslimited Non-Tech / Off Topic 27 June 6th, 2006 00:17
How can I identify if I have axle upgrade?? Elohim1 Modified Tech Discussion 5 June 21st, 2005 03:27
How to identify Non C-Clip Axle redsand187 OEM Tech Discussion 6 January 10th, 2005 20:05
