Old December 23rd, 2005, 15:51
SCW's Avatar
SCW SCW is offline
Ball joint, hubs, knuckle, other?
I tried searching but when you aren't sure what the problem is, searching is difficult at best.
My Jeep is suffering from loose steering, seems like you have some play before things grab to turn the tires. Today I looked at it really closely while my wife moved the steering wheel back and forth so that I could see what component was contributing to the wear, it's definately NOT the tire rods, they are very tight.
So...the tire rods are moving perfectly with the steering wheel, but when turning to the left it seems the front axle is shoved right slightly before the wheels start turning left, and vice versa for the turning to the right. This leads me to think there is something in the ball joints or knuckle that is loose and/or worn out. I looked it up in my Haynes (lousy book anyway) but all it says is that a ball joint takes special tools and isn't covered in the book.
Are ball joints something that could be doing this? Any other contributors? Are ball joints really beyond the shade-tree mechanic? Thanks-
PS, lots of wierd results when you search for 'ball joint', lol.
Old December 23rd, 2005, 15:56
87manche's Avatar
87manche 87manche is offline
Re: Ball joint, hubs, knuckle, other?
if the whole axle is shifting then look at the trackbar. That's what's supposed to keep the axle centered under the Jeep.
Old December 23rd, 2005, 16:52
SCW's Avatar
SCW SCW is offline
Thanks, I'll look at that specifically. what should I be focusing on, where it mounts to the frame, joint from bar to frame or the bushing on the bar? IOW, what is the common failure in track bars?
Old December 23rd, 2005, 16:55
bj-666's Avatar
bj-666 bj-666 is offline
there is a ball joint at the upper end of the track bar that mounts to the frame bracket and a bolt on the axle side either the ball joint is worn out or the bushing or hole that the bolt passes thru is worn.
Ball Joint removal SAFETY goodburbon Tow Rigs and Trailers 4 December 5th, 2005 21:06
ball joint removal/steering knuckle purchase RNMedic OEM Tech Discussion 4 April 12th, 2005 15:46
BEARING HUBS!!!! What's the deal?!? CheapXJ Modified Tech Discussion 32 March 18th, 2005 17:25
track bar ball joint spins ! generalleexj Modified Tech Discussion 2 March 15th, 2005 21:12
Ball joint Help! GroversXJ Modified Tech Discussion 6 December 19th, 2004 08:11
