Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > North Atlantic Chapter
North Atlantic Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Thread Tools Rating: Thread Rating: 23 votes, 5.00 average. Display Modes
  #601
Old October 29th, 2017, 08:23
ehall's Avatar
ehall ehall is offline
Re: beater!
Got my RCV problem fixed. The retainer clip wasn't left out it was just worn down, from the shaft moving around. Couldn't see it at first
Dug it out...
It looks like the shaft was only halfway in the CV, and the outer half was wallowing around the inner half of the inside CV race. The shaft is 4340 steel but the race is 300m, surprising how much damage to the race
Ordered a new shaft, race rebuild kit, and extra locking rings for the parts bag. RCV told me to buy o-rings to put under the locking ring to add tension, and the new shaft came with an o-ring already installed. However I wasn't able to press the shaft into the CV with the o-ring installed, and tore the o-ring during my efforts.
Went together easy without the o-ring. New shaft, CV joint, and Timken wheel bearings while I was at it. Also had to buy new spindle nuts (Dorman 615-110.1) and stake them into the groove--the stock Jeep hardware doesn't work since there's no hole for the cotter pin.
Short nail puller made it easy to pop the boots off
RCV D4042 installation tool made it easy to pop them on. Line everything up with hub bolts just loosely started, then crank down the hub bolts and it will push the boot on
Kind of a pain in the ass. Almost rather have u-joint 4340 shafts and carry spares like before. Almost. I have extra locking rings and tools in the bags, so if it happens again I should be able to repair on the trail or at camp.
my '91 beater rebuild
Old October 29th, 2017, 08:40
ehall's Avatar
Re: beater!
Went wheeling some private property in Crozet VA that was being leased by a club I was in. The club disbanded and let the lease run out, so last time to go.
Only real problem I had was when I tried to cross a gap and the tire pushed the rear rock back, then the wheel fell in the hole, and a support bar on the rocker rail broke off. Had to winch myself out and ratchet strap the rail to the side of the Jeep.
The other fella there broke his axle u-joint and tore both ears on the outer shaft. Neither of us had spares so we pulled his inner and jammed a rag in the tube. Then we went over to Bald Mountain Jeep Trail in the George Washington National Forest on the other side of I-64 and tooled around on the fire roads for a while.
Fun day overall. No real issues, although the engine and transmission did start running warm on the way back. I kind of suspect that the torque converter clutch isn't holding, so I may replace the transmission solenoids again
Old November 2nd, 2017, 14:08
Rock2pus's Avatar
Rock2pus Rock2pus is offline
NAC VP
Re: beater!
Sounds like a good day Eric! Sorry I never got down there to "do" Crozet, I've heard nothing but good about it. Hopefully something will happen with that again in the future!
I've also heard good things about GW state forest, would love to visit some time.
Rich
Old November 7th, 2017, 20:06
ehall's Avatar
Re: beater!
The rocker rails were given to me from a friend's part-out a couple of years ago, and were installed "temporarily" to give me some protection until I could do the work I wanted. To be honest I'm surprised they have held up this long--over 30 wheeling trips, some of them pretty brutal
The rails themselves are quite sturdy but the support bars that tie into the pinch seam and frame rail are very thin and flimsy. The one that broke seems to have simply sheared off at the weld, while another was crushed and rotted
I picked up some 1/8" square tube from a local welding supply for cheap and then welded it up with my cheapass 120v flux welder
Back in business
Still temporary, but much better than before, should last another year or two
Old November 8th, 2017, 06:22
Skorpyo's Avatar
Skorpyo Skorpyo is offline
NAXJA Member #241
Re: beater!
I was gonna reply and say "Pics or it didn't happen" but I see in the quote you had pics but your pics aren't showing up for me because you used HTTPS in your links and the certificate doesn't match the site name. If you change it to HTTP it works. Cool work!
Originally Posted by ehall View Post
89 MJ, a work in progress & 99 XJ with some stuff
Old November 8th, 2017, 17:06
ehall's Avatar
Re: beater!
Thanks for letting me know!
Old November 10th, 2017, 02:25
Demonoid369's Avatar
Demonoid369 Demonoid369 is offline
beater!
Let's see if the http trick works lol
Edit:it does work, I can see your pics now Ehall
Old November 10th, 2017, 04:05
themauler's Avatar
themauler themauler is offline
beater!
Time for an AX-15 Swap!
Old November 10th, 2017, 06:26
ehall's Avatar
Re: beater!
Mozilla is ignoring the images now too. Looks like I need to create a new certificate.
Old November 10th, 2017, 07:13
Skorpyo's Avatar
NAXJA Member #241
Re: beater!
Yeah, SHA1 certs are globally being unsupported. We went through a huge effort where I work for SHA256 conversions.
Old November 10th, 2017, 14:07
ehall's Avatar
Re: beater!
Back to plain old HTTP then
Today I upgraded my transmission and power steering cooolers to B&M 70273. 11" wide x 5.75" tall x 1.5" thick, supposed to be good for 15000 BTUs. It has 1/2" NPT fittings on the ends, so I bought some AN-6 adapters (JEGS #100119) and 3/8" elbows (Earl's 709167) for the soft line connections. Tight fit, had to wiggle the thing in one end at a time then thread the elbow fittings on afterwards. Also drilled a hole in the crossmember for the transmission return line, using a stepper bit to make the hole bigger than the hose.
Both installed... Zip ties through the radiators and foam pads to keep them off the AC condenser, so didn't have to cheat. Plenty of room on the sides for the radiator tanks and some of the fins.
No interference from the grill, can't really see them either.
Took a whole quart of power steering fluid to fill the cooler. We'll see how it holds up tomorrow.
Old November 13th, 2017, 15:42
ehall's Avatar
Re: beater!
Wheeled at AOAA this weekend. Everything worked, nothing broke
Old November 18th, 2017, 17:10
ehall's Avatar
Re: beater!
Few loose ends on engine work for the year. Everything is working very well with one exception, and that is working pretty well. Some of this stuff was done recently, some of it earlier in the year.
I could smell coolant burning sometimes, and temperatures were fluctuating a little, and there was a mystery coolant loss. Today I saw a drip drip, and it turned out that one of the heater hose clamps was defective and the hose was leaking around the edge. Replaced them all with junkyard constant tension clamps, no more smells or fluctuations.
Throttle cable broke at the clip near the throttle body, so I got another from the junkyard and replaced it.
Also swapped in some clean valve cover hardware to replace my rusty old bolts.
Mitsumoto silicon elbow for the throttle body to the tube. I kept trying to make the stock elbows work but they kept tearing at the inner elbow. This silicone elbow is very nice, fits nice too.
Also got a new air filter to replace the one that I have had for a while. This time I splurged on the sock to keep leaves and water off of the filter element. I am using a throttle body elbow from a V8 ZJ, fits nice and snug inside the amsoil filter opening. I am keeping my eyes open for a silicon adapter elbow but not really looking hard, since I plan to plumb this into the cowl again at some point. Also replaced the Spectre element on my manifold breather (for the diff, transmission, and transfer case breather lines).
New plugs and wires, distributor cap, etc. earlier in the year.
Everything is running top-notch EXCEPT the transmission is not acting as I expect on the highway. For one, fuel mileage is down to ~10 MPG when it should be closer to ~14. Also the transmission has not been running as cool as I would like--I installed the new coolers which addressed the symptoms (runs much cooler), but thinking about it I should not have to put 15,000 BTU cooler on the trans to make it run in spec. Both symptoms point to torque converter clutch engagement issues, however the TCC lockup seems to work just fine--I can feel it shift and RPMs drop as expected. My working theory at the moment is that the old solenoids have damaged o-rings and are not sealing the hydraulic circuit for the TCC fully, allowing some fluid loss and therefore some slippage. I am going to swap in the set of aftermarket solenoids again, and see if they work better.
Other than that the Jeep is 100% and is a pleasure to drive
Old November 26th, 2017, 07:27
ehall's Avatar
Re: beater!
Drove to Roanoke VA to get some parts from goodfellow xjtrailrider, and wheeled in GWNF with his local club. Ton of driving, everything worked, nothing broke. Smell of burning coolant came back on the hill climbs, so might have another leak.
He's addicted
Old December 3rd, 2017, 07:32
ehall's Avatar
Re: beater!
When I got this POS the AC didn't work at all, but over the course of a couple years I rebuilt the plumbing enough for it to hold pressure (condenser, evaporator, and a couple of hoses), but never got around to replacing the compressor. It had problems (noisy), but it had the factory service valve contraptions for the R12 fittings, and I had to spend some time researching a solution.
Since I had to evacuate the system for the heater core swap, and its almost winter here so I don't need AC right now, I decided to spend some time working on it.
It would have been simplest to just buy another R12 compressor and new service valves but the fittings are not publicly available anywhere and have a bad reputation anyway. The valves are actually available from 4 Seasons, but they are not listed in the public catalogs correctly and do not show as interchange. You can call the 4 Seasons desk and they will tell you what to buy.
Another issue is that the entire HVAC infrastructure changed in 1997, moving from expansion valve to orifice tube and accumulator design. Some of the hoses and fittings are the same but the connection at the firewall was specifically different.
What I came up with instead is 94-96 HVAC parts have the same infrastructure (same condensor, expansion valve, etc), but are factory for R134A instead of R12. I bought a new 1995 Denso compressor, a pair of 4Seasons 1995 suction and discharge hoses, and a 1995 filter-drier with pressure switch, then kept everything else the same.
The port fittings on the back of the compressor are different from the fittings on my old R12 compressor but are the same as the fittings on the side of the service valves. Unfortunately the angle of attack is different, and can't use the old hoses without the service valves because that's the only way to charge the system. Meanwhile the new hoses come with R134a service fittings brazed into the line.
Need to replace another part and get it recharged, and then wait for warm weather, but I feel pretty good about it.
Rate This Thread:
My new beater hollywood32 SoCal Chapter 11 March 9th, 2007 18:34
87 xj beater treedoc For Sale: Private Party Only. XJ ITEMS ONLY 1 May 3rd, 2005 18:38
Hey Cat Beater! Lawn Cher' South East Chapter 3 April 29th, 2005 05:47
$200 beater XJ olivedrabcj7 Modified Tech Discussion 20 February 1st, 2005 16:45
beater? skunkman Tow Rigs and Trailers 2 October 10th, 2003 08:26
