The kit is plug and play cept for pulling the steering wheel to put the new clockspring in there, clock spring is what allows the electrical connections to stay when you are turning the wheel. Careful around the airbags.
After you get it all in and reconnect the battery lay your drivers seat down flat with you in it, put the key in and start it up then turn the wheel a few times back and forth. Don't stand outside and turn the key, if the airbag for some reason does go off it will break your arm or worse...
