hbtmcg
- Orlando, florida
I've been crusing the archives to help me solve my hunting low idle problems for the last week.
What i've done:
Replaced IAC, TPS (and then set it with DMM), MAP sensor
Replaced: Throttle body with a used one AFTER i cleaned all the orfices with throttle body cleaner, toothbrushes and small brushes
I don't believe I hace a C101 connector though I hae check all the connectors under the hood
I have check and rechecked the vacuum lines and replaced the only one that had a loose fitting.
I can't figure out what to do next.
1989 Wagoneer Ltd. I6 Renix,
What i've done:
