extended brake lines for 3" lift w/ABS
Codhead
Va
I'm installing a 3inch lift on a '95 that has ABS. Can I use ZJ or TJ lines to replace stock and get the needed length? If so, is there a particular year that would be best?
Use YJ brake lines. I believe i used them from a 94 YJ for the front. I used a braided SS from RE for the rear.
Will the YJ front lines work on the front and the rear of the XJ? Should I get them at the dealer, or local parts store (any diffence in OEM or aftermarket products?).
